Micro Sidewinder connector ??
Hi
I'm building my XR10, and I put 2 Micro Sidewinder on it... but, I can't find an connector that fit in the connector on these ESC.. I bought them over a year now. I have some Castle connector here but they're too big even the 4mm.... Is it 3.5mm connector, and discontinued from Castle ?? :neutral: thank to let me know if I can find this somewhere.... :yes: |
Just says universal on the product page- was it the motor or battery connectors you need to find?
You can buy small bullet connectors cheaply enough if you want to just swap them over, very simple soldering job.. |
this is motor connector that I look for, but can't find any info on this...:neutral:
you right maybe just take other brand of plug... thanks :wink: |
3.5mm bullets. I've used both novak and hobbywing brand bullets with the castle connectors with no problems. I am sure almost any brand of 3.5mm male bullet plugs would fine, as they are fairly standard in shape.
Kieren |
| All times are GMT -4. The time now is 04:00 PM. |
