-   -   Tekno Emaxx Wing Mount (https://www.rc-monster.com/forum/showthread.php?t=30530)
USARUSH 09.29.2011 04:21 PM
Has anybody broken one... I have, its just the little metal crossbrace that attaches to the shock mounts... Any advice as to fixes or parts numbers... Im using zip ties at the moment
suicideneil 09.29.2011 07:04 PM
Trace it only some thicker aluminium sheet/plate ( 1/8" or 3mm should do nicely ) and cut out a new one- you only need a hacksaw, cordless drill and some small hand-files. :yes:
USARUSH 09.29.2011 09:55 PM
That is sooo much easyier said than done.... I think I may stick with my zip ties till I get some FLM shock towers..... Mostly cause I'm lazy, partially cause Im not sure if I could ACTUALLY work the metal without drawing my own blood:diablo:
:angel:The things we do to keep our wings?????:angel:
Thanks Neil:mdr:
crazyjr 10.06.2011 10:56 PM
Dude, I am the laziest guy i know and a fair bit clumsy. I made an adapter for using a RC-monster Revo motor mount in a RC10GT, It only took 20 minutes and no blood. Most any lowes or home depot type store has the material and it shouldn't take more than 5 minutes to make. But i guess Zip-ties can work
ZippyBasher 10.07.2011 09:24 PM
http://i264.photobucket.com/albums/i...v/100_5560.jpg
Or just make it a square and drill the holes in the right spots. who said it needed to be an X shape. I sandwiched a shock tower and then used ball links for spacers inside... The wing mount bolts right on there very simple
George16 10.07.2011 09:34 PM
You can do it. It's easy. "If there's a will, there's a way".
USARUSH 10.07.2011 09:34 PM
So what did you use to cut that metal???:surprised:
Looks rough, but tough as nails
USARUSH 10.07.2011 10:04 PM
Oh, I'll get er done all right:yipi::yipi::yipi:
to tell you the truth the wing is wayy down on the to do list with ma MAXX:cry:
I got 1/8 diff problems :diablo:
Always something with MAXX:cry:
George16 10.07.2011 11:49 PM
What's your problem with the diffs?
USARUSH 10.08.2011 08:37 AM
Im going to move this over to the UE thread
