-   -   Power supply (https://www.rc-monster.com/forum/showthread.php?t=30666)
captain harlock 11.14.2011 01:23 PM
Power supply
Hello!
I bought a Hyperion 720i dual charger from Mike a while ago, and I have no idea what power supply shall I buy for it.
For now, I only want to charge x2 3s packs. The chance is big that I'll be charging x2 6s in the near future.
The only rc devoted company that makes super power supplies is ProTek RC, AFAIK. They've got one that makes 1000w, and one that makes 2000w. Both are pricey.
I'm leaning to the ProTek Super Pro 1000, but I'm not sure if it'll handle the load the 720i will put on it when charging x2 6s packs at 10- 20A.
Anyone has any advice here?
Arct1k 11.14.2011 01:33 PM
Buy a cheap server power supply and convert it...
Arct1k 11.14.2011 01:34 PM
Oh and put some flame stickers on it :)
brian015 11.14.2011 02:32 PM
+1
How to build a $20 47A power supply
E-Revonut 11.14.2011 03:06 PM
or buy a deep cycle battery and a cheap 12v battery charger to maintain it. Then you could also charge even when power is non existent
captain harlock 11.14.2011 03:29 PM
Very nice...but, I'm quite the snail when it comes to understanding the conversion of electric stuff.
captain harlock 11.16.2011 09:54 AM
BTW, just today I came to know that MaxAmps sells a very powerful( 47A, 1150watts) power supply for a reasonable $150+. Has any of you tried their PS?
BrianG 11.16.2011 11:08 AM
Yeah, they have two models, a 12v and a 24v. Both versions just use the same HP power supply modded as found here. The 12v version is basic enough, but I'm not sure if they modded the 24v version properly (decoupling the output ground from the case/earth ground). Either way, it's a fairly cheap high power solution if you don't want to mod your own, but you'll be paying around $100 more for that convenience (those supplies can be had for around $25).
Arct1k 11.16.2011 11:17 AM
But you get the flamesfor the extra $100
BrianG 11.16.2011 11:24 AM
True, that makes it worth the extra cost then. I forgot about that. Thanks for the reminder! :smile:
captain harlock 11.16.2011 01:12 PM
Lol!
I'll do more research. I don't think I have enough guts to modify a basic PSU just yet.
Thanks a lot Arct1k, Brian and the others. Good feedback with some spice..:)
brian015 11.16.2011 01:13 PM
Originally Posted by captain harlock (Post 413975)
Lol!
It's easy - you don't have to open up the server supply - just add a jumper and some leads on the outside.
BrianG 11.16.2011 01:21 PM
Captain, if you were in the US, I'd suggest to send the supply to me and I'd mod it for you (the 12v version). I'd even boost the output to ~13v and add banana posts and you'd still save well over $50. But after shipping, you'd probably come out the same as just getting it from Maxamps.
Like brian015 said, you don't need to open it up. Adding a jumper to the external pins works fine.
BrianG 11.16.2011 01:36 PM
Just found this lot of 19 575w HP power supplies. Cost+shipping is ~$200. Figures out to under $11 each. Not bad if someone wants to buy a bunch and re-sell them, or do a group-buy...
