whats your fastest 1/8 scale buggy set up guys?
heres mine ofna lx1e gearing 51/30 nanotec 6s 60c 5000mah mamba monster and neu 1512 2650 nitrohouse tri level wing grp tires and my rear diff spooled also my center is spooled.what i also would like to know is will a delrin spur last drag racing?
heres my new set up....1.gearing 46/33 custom cut t6 alum.billet 2.rear spool and center spooled 3.monster and 2650 ,motor timing zero no room to run it at 500 ft its still accelerating i only speed pass now.FINAL GEAR RATIO =1:39=theoretically 128mph but in a buggy no way!!mabe in a onroad car but buggy no way.realistically 105 -110mph!
How did you spool the rear diff? If you don't mind sharing. Thanks
CEN sell lockers..
Okay, I think, I got it.
How do you, hold the, spring "cutlets" in place? Linc, I bought a bunch of mine from here. |
EXACTLY THE SIZE OF RICE
leave it alone Harold, just walk away. Put this entire thread out of your mind and behave. Dear God this is hard... |
mmmm, cutlets.
the spring cuttlets will lock themselves make shure that the diff. closes smoothly.when you close it see if there is any "play" movement in the diff.badda bing.
Have you ever tried putting silly putty in the diff? Surprisingly, I'm not joking. A lot of Slash people around here put it in their diff because the Traxxas diffs leak so bad and it seems to lock them, perhaps a little slip but overall pretty stiff stuff. Just a thought.
Delrin spur should last a while if your mesh is set right and the motor mount doesn't flex. Pretty hard to snap those teeth off with straight torque but it isn't impossible. I think my Hyper 7 runs around 50 MPH as it sits but it's just a parking lot basher. You should be able to push 90+ with your setup if you do just speed runs/drag racing but watch those temps!
Delrin is actually a brand name - the actual product is a plastic called Acetal. It is a high strength, dimensionally stable engineering plastic with high natural lubricity and low water absorbtion. ;)
| All times are GMT -4. The time now is 02:13 AM. |
