Stock tire/rim size is a 30 series correct for Losi 10T
just picked up a new one that was never used cheap and it has the RCM conversion! It just needed shocks and tires...I have a set of shocks so no biggie there. The tires I believe are a different size than 2.2 if memory serves me. Now, the other questin is which one of these will fit, front or rear or do I need one of each....
http://www.amainhobbies.com/product_...Wheels-Black-2 http://www.amainhobbies.com/product_...Wheels-Black-2 |
the original wheels/tires were from a 1/10 buggy, actually. 2.2s are commonly used on these little beasts, though.
Ok thanks Mike...I was searching BrianG's Ten T thread and in it you mentioned using 30 series wheels at some point due to axle sizes being different...or something like that anyway.
So, will the one's I mentioned above actually fit? |
30 series is basically a low-sidewall version of the 2.2(kind of like VTR vs MTR in truggy tires). - the 30 series wheels and tires will fit fine. :)
Again, Mike, thanks for you input!
out of curiosity, what are you guys running for tires on your ten t?
Although the RCMonster answered my question regarding if the tires I listed above will fit, I am still unsure if I need a set of each or like the CRT.5, just the fronts
| All times are GMT -4. The time now is 11:01 AM. |
