-   -   Lehner question (https://www.rc-monster.com/forum/showthread.php?t=30840)
roost 01.04.2012 03:16 PM
Lehner question
Can you cut the lead shorter on a 6 connection motor? I want to put bullets on it
bdebde 01.04.2012 04:07 PM
It is not recommended, the wires have a coating on them just past the bare part. i have done it before, but you have to get the coating off to get the solder to stick, heat will help with this (just not too hot!).
roost 01.04.2012 05:02 PM
Thanks for the reply. think ill give it a shot, just wasnt sure if there was a reason for them being so long
One more question, how do you calculate the what kv it would be in "star" configuration. Motor is a 2240/7 hi amp if it helps any
RC-Monster Mike 01.04.2012 07:34 PM
Whatever the Kv is in Delta mode divided by 1.73 will give you the Kv of the motor in Wye mode and vise versa(Wye Kv times 1.73 = Delta Kv).
