-   Novak (https://www.rc-monster.com/forum/forumdisplay.php?f=42)
-   -   samarium cobalt tuning rotors (https://www.rc-monster.com/forum/showthread.php?t=30923)
crazyjr 01.16.2012 05:58 PM
Whats up with this? How close is the power between neo and this? I know you built it Primarily for heat resistance, but does the motor lose any power to the neo setup?
Bob Novak 01.17.2012 08:29 PM
Neodymium (Neo) vs Samarium Cobalt (SmCo)
The output power of both of these rotors are very similar. Our motor design is based on a 28 MGOe energy product magnet and the SmCo is also rated at 28 MGOe (MegaGauseOerstead). The difference comes into play as they heat up. Since the SmCo Rotors have a very high coercivity (coercieve force), they are not easily demagnetized. Thus the SmCo Rotor can tolerate about 250-350 degree F more temperature rise than a Neo magnet before they began to lose their magnetic power.
The Curie temperature of a Neo magnet is around 320 degree C and SmCo magnets is around 800 degree C. What this means is if you heat a magnet without an external magnetic field the magnet will lose all its magnetic properties at the Curie temperature.
Also the coefficient of remanence of a SmCo magnet is about ¼ of Neo (-0.03%/C vs -0.12 %/C). Remanence is an indicator of materials ability to hold magnetization (magnetic storage). The lower coefficient shows a ¼ lower loss of magnetic force due to increase in operating temperature.
Of course you cannot run the motor this high a temperature due to other components in the motor but it will make the motor output power stay flatter for a longer time.
Bob Novak
E-Revonut 01.18.2012 12:26 AM
Thanks for the expanation! I just ordered a Premium Balistic Spec motor last week and didn't see this then but seen it when I went on tonight. By the way I received my motor today and won with it tonight. Awesome motor, well worth the extra money!!!
snellemin 01.18.2012 12:49 AM
Will the Ballistic 8 motors have this Cobalt stuff as an option?
NovakTwo 01.20.2012 02:53 PM
Apparently, we do have SmCo magnets for testing in the B8.
snellemin 01.20.2012 03:01 PM
NICE!!! I want/need one for the Delta wound motor for some more gearing.
suicideneil 01.20.2012 07:50 PM
Obvious question time: What is the price like on SmCo vs Neo?
snellemin 01.20.2012 09:11 PM
I'm guessing the cost is going to be higher. Astro Flight motors uses the same smco stuff and their motors are pricey.
NovakTwo 01.21.2012 12:44 PM
Depends on what day it is....
For a while we couldn't even get quotations for our Neo rotors; so, it's both price and availability. Neo rotors require an additional rare earth material that is also very expensive and sometimes hard to get----I think that it is dysprosium.
NovakTwo 01.22.2012 01:28 PM
Samarium Cobalt (SmCo) vs Neodymium (Neo)
We added a tech note ( PDF format) linked from our home page / right column:
TeamNovak
crazyjr 01.22.2012 05:42 PM
So basicly the design is two-fold, 1. the rotor will almost never demagnetize, and 2, brakes will never fade in theory. Nice ideas for racing
snellemin 01.22.2012 05:49 PM
But isn't the Cobalt stuff a bit more brittle?
NovakTwo 01.22.2012 06:58 PM
Yes, it is. It must be handled more carefully when outside the motor. We did a complete incoming inspection and there were very few dinged in transit from China. We also perform torque-tests on all rotors to make sure the magnets have been glued to the shafts properly.
ta_man 01.22.2012 10:31 PM
If these are coming from China, arean't you exposing yourself to the same pricing instability for these as with the Neo magnets?
NovakTwo 01.23.2012 11:00 AM
During the availability/price crisis of last year, the SmCo prices didn't skyrocket like Neo. I don't think that rare earths can be mined affordably anywhere else; so China will be the supplier. China completely closed their Neo mines for a period last year.
Many motors, of all sizes depend on Neo for magnet material; the situation affected other motor mfgs, not just R/C. When Adnan went to China on his last trip, he visited one of the Neo mines and met with additional mfgs who can fabricate rotors. Sourcing magnet materials will be a continuing problem.
