Motor Shaft Flat Spot
Hi there,
I need to get some machining done and am after some measurements. Can anybody tell me how far in the flat spot is on an 8mm motor shaft? http://dl.dropbox.com/u/327064/Revo/...or%20shaft.png I will greatly appreciate anyone who can help, thanks :) |
Yeah, about that ( I had to grind one on my old Medusa motor I think ) seems right- more of an eye balling thing really; I used a dremel & grind disc just until I was happy the spot was wide enough, doesn't have to be perfect so long as you don't go mad.
Well I designed one in Sketchup with a 1mm flat spot and it does look about right, so I'll go for that.
Thanks :) |
| All times are GMT -4. The time now is 09:25 AM. |
