a question about the Cap Pack
I was wondering the difference the 01100020 version and 11000202 version
CapPack 01100020 CapPack 11000202 |
The 2 at the end of CapPack 11000202 obviously is their code for "$2 more expensive for the exact same thing"
Maybe it means they put post's on that will take wire larger than 12awg without having to learn a new magic trick. Using one on my baja and it works but it was not easy getting the XL wires soldered on, still not comfortable with it.
I use this "trick" when soldering wires on Tekin ESC solder posts. |
Really the biggest problem when using the cap pack with the XL is the posts are too close to the caps. More of a clearance issue with that 8awg wire.
I was thinking that 011000202 was replacement for the mamba XL and 1100020 is from the mamba monster extreme/upgrade for the mamba monster.I looked on tower hobbies because they have a more detailed description of product and their was no 1100020 model number. :whistle:
| All times are GMT -4. The time now is 05:57 PM. |
