-   -   Gearing?????? (https://www.rc-monster.com/forum/showthread.php?t=31098)
anunaki 02.29.2012 07:49 PM
Gearing??????
I tried off road this weekend and love it but I know nothing about off road so is 47/14 over geared I use the 2650 castle and mamba monster on 6s I only have 6s so is 47/14 on 6s over geared or under geared and what timing should I use for off road bashing?
fastbaja5b 02.29.2012 09:03 PM
on what? If you run 14/47 with a 2650 on a 40 pound truck with 8 inch tyres I dare say you're overgeared
But isn't the 2650 only warranted up to 4s lipo?
anunaki 02.29.2012 09:56 PM
my offroad buggy is a ofna lx2e its about 7 pounds I just dont know any thing about offroad sooo is 47/14 in the lx2e it should run cooler with more volts right?<ques?
hemiblas 02.29.2012 11:04 PM
It only runs cooler on 6S vs 4S when you gear down to compensate. If you take a truck geared for 4S and run it at 6S it will get very hot very fast. Hopefully someone can chime in if they know anything about that buggy. As fastbaja mentioned the 2650 is not rated to run at 6S so you are going to be running very high rpm.
anunaki 02.29.2012 11:47 PM
Yeah thats why i need advice on 47/14 in a 1/8 ofna buggy on 6s I only have 6s I have a 51 gear also which gear 47 or 51 will run cooler?14 pinnion
fastbaja5b 03.01.2012 01:26 AM
shouldn't run the 2650 on 6s
slimthelineman 03.01.2012 03:00 AM
Also for a given motor going up in voltage will increase temps regardless of gearing from my experience. You will just plain make more power. The only way to offset this that I know of is to go down in kv as you go up in voltage. Keep your target rpm the same by varying the two and your temps will go down. The 2650 can be run on 6s but it's impractical for anything other than speed runs. Most guys I race with that ran that motor were in the two to three cell range. It's hard to tell with gearing without knowing the internal ratio and driving style. I find that driving style will vary the gearing by up to two teeth. I would say gear it as low as you can and keep an eye on temps until you can get a hold of some 3-4s batteries and or a lower kv motor.
anunaki 03.02.2012 01:38 AM
Swaped out the 47 & now have 51/14 runs cooler on 6s now
magman 03.02.2012 04:55 PM
A much better motor choice for a 6S set up would be a 1400kv Tekin motor. It would run much more efficiently. Even a 1700kv motor would be much better than than the 2650kv as far as efficiency
magman 03.02.2012 04:57 PM
General rule...the more cells you are running, 5s, 6s, the LOWER the kv motor you should use. Of course there are exceptions to this rule...drag racing, speed runs, etc...
anunaki 03.03.2012 12:51 AM
Mind you im.new to off road and I run 51/14 on 6s in a ofna lx2e with 2650 I ran it bashed it for 20 min me and my son and mo tor was just at 178° also I have two cap.packs also and a rx battery heres my science the more I feed the mamba system the better it preforms tried and tested I know it voids my warranty but for me 6s in a 1/8 scale buggy is my rc heaven off roads fun but dirtyyyyyy.DIE HARD CASTLE CREATIONS FANATIC TEKIN WHATTT???
MiamizFinest 03.03.2012 02:07 PM
Dude, you never called to me see your car run on 95!!! now your taking it off-road that sucks!!!
Becarefull with that 2650KV on 6S, undergeared like that your going to rev it to the moon and pop it!
anunaki 03.03.2012 02:34 PM
[QUOTE=MiamizFinest;418751]Dude, you never called to me see your car run on 95!!! now your taking ,i still haveit off-road that sucks!!!
Becarefull with that 2650KV on 6S, undergeared like that your going to rev it to the moon and pop it![/QUO
I work so much and two kids shi* I dont have time to drag race or speed run I still have that buggy but I drive trucks so I bash all over the u.s.besides theres no one to race
anunaki 03.03.2012 02:42 PM
Is 14/51 on 6s in a 2650 in a lx2e 6pound buggy over or under geared ?somone please help
Overdriven 03.03.2012 07:39 PM
14/51 on 6s with the 2650 puts you at 65mph. That's generally over geared for a offroad setup. You're also not using he motor in it's intended fashion. The best thing for you to do is pick up a 4s pack and use that for offroad with your current gearing, use the 6s on the street. Either that or pick up a lower Kv motor, 1600-2000kv for 6s offroad. I run a CC1518 (1800kv) on 5s geared 18/51 in my LX1e and it's nuts offroad. Way too much power, but for an all around basher that can do around 50mph (with 18/51) it's alot of fun.
