Hyperion vs iCharger
Hi everybody. I'm thinking about a quality charger. I know both are good, but speaking intelligence wise,
which one has a more precise balancer and is gentler with lipos? I'm ready to hear your opinion and experience I personally have heard people are getting tighter cell voltage tolerances with Hyperion. Don't know about lipo cycle life though... |
I swear by Hyperion. I love their charger, it balances everything perfectly and it is easy to use.
I suggest you consider the Cellpro Powerlab 8, since you mention the Hyperion.
Any of the 3 chargers mentioned in this thread will be adequately accurate, and none are rougher or gentler on lipos than the other. |
Look at the watts!
I switched to i-chargers a couple years ago, at the time they had the highest watt output per dollar. They are great chargers. The higher end (and newer) models have closer balancing tolerance.
Bottom line; always check the watts of the chargers you are comparing... a lot of cells and a lot of amps do no good if the watts are low. |
I still like my old hyperion.
https://encrypted-tbn2.google.com/im...5JWw0SXM7F70WQ Like Paralyzed mentioned it's your settings on any charger that determine how brutal the cycles are. |
Yeah, You can chose the charge rate(amps) and even max cell voltage in some cases.
I use Hyperion chargers myself, along with Hyperion Lipos. They are fairly priced with high quality you can count on. I am sure there are other nice chargers as well, but I have no reason to switch(and I am a reseller for Hyperion already).
| All times are GMT -4. The time now is 05:08 AM. |
