XO-1 1717 (1650kv) vs Neu-Castle 1717 (1580kv)
Before I push the button on the the XO-1 1717, is it the same size as the older one castle stopped making?
Same size but with Newer rotor design.
Excellent...just got to bid well on one. Thanks friend.
Info from Patrick:
http://www.rc-monster.com/forum/show...30&postcount=9 |
We can assume that the can on these 2 motors are identical, just different stators?
What do the numbers 1717 signify ?
Edit: Listen to him, not me \/ \/ \/
I am pretty sure the 1st pair of numbers indicate the stator diameter and the 2nd pair indicates the rotor length - a 1717 has 1.7" stator diameter and 1.7" rotor length(magnet). A 1521 would then be 1.5" stator diameter and 2.1" rotor length.
Wouldn't that make it a 1716 or a 1715? |
Thats exactly what I was thinking .....
I guess it depends on how much shorter, doesn't it - if the new rotor is .01" shorter, it would still be closer to a 1717 than a 1716 and therfore fitting of the moniker(while still being shorter and lighter as Patrick described it).
| All times are GMT -4. The time now is 10:59 PM. |
