-   -   My Monster is LOOSE! (https://www.rc-monster.com/forum/showthread.php?t=31271)
bdebde 05.10.2012 03:06 PM
Well, loose in the case. The circuit board rattles around quite a bit in the case. This is brand new spare I got as non-warranty replacement several months ago. Any good ideas to stop the rattling around? Thanks in advance.
BrianG 05.10.2012 04:09 PM
What about some of that thin craft foam? You can get 1/8" thick 8.5"x11" sheets at Wal-Mart or any craft store for about $1 each. Just try to cut the foam so any heat-producing component (like BEC FET/coil) is exposed and has some room to "breathe".
bruce750i 05.10.2012 04:50 PM
http://www.biosafe-inc.com/_photos/s...oegoo_logo.jpg
In moderation of course.
fastbaja5b 05.10.2012 09:11 PM
Should you have to do this on a $130 esc? Especially one that as you say is brand new.
Be like buying a Toyota and all the wheel nuts and screws being loose!
bdebde 05.10.2012 09:25 PM
Great ideas, I have some of that foam around somewhere... and I thought about shoo-goo, but was not sure if that was a good idea (why I am asking).
It was only a $70 ESC, LOL... replacement for a scorched one. Still, it should not be required on a new ESC as you say baja.
josh9mille 05.10.2012 09:30 PM
For being a devout CC hater you sure do spend a lot of time posting here.:whip:
BrianG 05.10.2012 09:45 PM
You are right, you shouldn't, but there is nothing stopping anyone from using a different product. Then again, if you are paying $130 for a Toyota and the only thing wrong with it is the wheel nuts and some screws, you really can't complain... but I'm sure you'd manage.
nativepaul 05.11.2012 08:36 AM
I see that as a $200 ESC, $130 to buy it then $70 to get it going again.
I would favour foam rather than shoe goo as it makes service easier should it need it again in the future.
If I was to glue it I would go the hole hog and waterproof it with electronic safe silicone sealant, I would only consider that if it is out of warranty though, and I have no idea if castle give a new warranty with replacement ESCs or if the warranty continues from when you bought the original, which in your case I'm guessing has expired hence you having to pay for your replacement.
bdebde 05.11.2012 10:23 AM
I like the waterproof idea, could have used that at the track last weekend... or a boat, :lol:
