-   -   "Drag Racing" start battery (https://www.rc-monster.com/forum/showthread.php?t=31307)
PBO 05.31.2012 05:59 PM
Saw this battery in a drag racing project, it caught my eye because it's installed & not much else is. When I asked why I was told "it's worth $3K because it only weighs 3000grams & has huge cranking ability"...presumably it was bought ahead of time because of the difficulty in purchasing & installed?
http://i703.photobucket.com/albums/w...h_6467b392.jpg
It doesn't have any labelling or identifiers. Anyone know anything about these things?
josh9mille 06.01.2012 10:33 AM
worth $3000? It must be a MA product!
nativepaul 06.01.2012 12:13 PM
I would use a 4s1p 5000mAh Lipo for a turboed street machine or 4s2p 10,000mAh for a high compression N/A strip weapon (I've started a neighbours deisel car on a 4s1p 5000mAh chinese LiPo) and secure them with bent alloy trays pop-riveted to the tub/spaceframe and held in with velcro straps, Even 2p should weigh under 1200 grams and cont under $500.
I've been thinking of a 4s4p A123 pack for my road car to dump some weight up front, it should be man enough to cope with what the alternator can chuck at it, its not a drag car so I wouldn't want to bother with taking it out and charging it externally to save a kilo and it would still be 10kilos lighter than stock.
Brow 06.01.2012 07:56 PM
What car is it in? Who owns it?
It looks a little like an Odyssey battery but at $3k are you sure someone wasn't having a private joke with you?
zeropointbug 06.01.2012 08:41 PM
I would buy 4 20Ah A123 prismatic cells from A123rc.com, $32 right now, they can dish out 600 - 700 amps no prob, make it a 2p pack and that's 40Ah and ~1200 - 1400 amps.
PBO 06.01.2012 09:46 PM
RX3 & I believe it may have been an 'MA moment' for the guy - in that he bought overpriced junk
http://i703.photobucket.com/albums/w...h_a1edf922.jpg
http://i703.photobucket.com/albums/w...h_ed0f2c4c.jpg
http://i703.photobucket.com/albums/w...h_b4959894.jpg
Brow 06.01.2012 11:21 PM
Thats a pretty serious chassis/cage and big tyre combo. I would be assuming turbo rotary going in the front and quite possibly 8sec or quicker on the quarter mile.
I used to run a drag car in my past and know a little about them. I used to run Odyssey batteries capable of putting out 650 amps under cranking load for about 20sec. Used to start a 460 ci big block ford pretty quick. I really don't know how lipo or life batts would handle high current for 5-10secs at a time cranking a big block over. I certainly don't think the leads would hold up to it. I would also be concerned for the internal batt connections.
Byte 06.03.2012 06:27 PM
At what C rating are they rated? They're very cheap imo, damn!
