need some esc advise please...
i'm running an mmp with the castle 2400kv sct motor a castle caps bank on the esc. usually i run it on 3 or 4s and it does great. today for shits and giggles, i decided to put 5s in it and see what it had. (this is all in my slash 4x4) I'm also running 40C 5000mah packs
when i squeezed the trigger, it crawled. then all of the sudden it comes alive and drives perfectly. then it does the same thing. i pull the trigger and it barely rolls...then i start feathering the throttle a bit and it seems to get it's ass back. any one know what this is? like i said, it's perfect on 4S, but the 5S was really acting funny. could it be i was overgeared or something? any help is appreciated. thanks |
Have you updated the ESC recently? I have had some older ones do that after new firmware. You could try earlier firmware and see if it goes away.
i'll try that, thanks for the advise. :)
UPDATE...i rolled back to 1.26 and that did it. thanks again for the help. |
| All times are GMT -4. The time now is 09:49 PM. |
