MBX6 and LST2 Drive shaft diameter
Hi guys. It would be very nice if any of the mentioned car owners could measure the diameter of the end ball and the hole of front or rear driveshaft. Wondering if they are the same:neutral:
http://www.part.lt/img/fac57ef693680...5b49724904.jpg |
lst shaft = 10.8mm end ball and 6mm hole and 2.5mm slot
Thanks alot. Now just need someone with Mugen to chime in.
Mugen doesnt seem to be very popular :whip:
Posted this on other forums and didn't get any replies either... |
I am pretty sure that they are the same. The inner bearing is the same. 15x21x4. I will say this. The LST and LST2 balls will not be the same. The LST2 and Mugen have bigger balls. Yes Harold.
I will be able to tell you soon. I am ordering the Mugen shafts. -Zack |
I can measure my mbx6t drive shaft or you are looking for the mbx6 buggy shaft?
Now I don't have calipers(its on my list), but i did measure the Mugen ball is around 11.5mm barely larger than the Losi LST that PinkPanda posted.With calipers it could have even been dead on with 10.8mm as PinkPanda posted. I will say it again the LST 2 or XXL is probably what he is talking about because the plain LST will be smaller. Also I failed to measure the hole and the slot.
| All times are GMT -4. The time now is 01:24 AM. |
