-   -   Slash 4x4 Night Run (https://www.rc-monster.com/forum/showthread.php?t=31421)
redshift 07.13.2012 01:43 PM
Slash 4x4 Night Run
4 Attachment(s)
Hey guys, thought I'd share a fairly simple little project. I lost my father in the spring, among the things I inherited was a Slash 4x4. The first thing I wanted to do was switch to Lipo, and of course the Velineon ESC didn't live past the first connection with 3S... So I put in my old Mamba Max, the one that powered my Maxx Mutation BTW..
3S is ideal for using the LED strips, so I added a JST lead for the LEDs.
I bought some Super Bright LED strips- http://www.valuehobby.com/accessorie...rip-white.html
I didn't want to change the look of the body too much, so I decided to put them on the inside. I cut the holes with a paper hole punch (where it would fit) and used a square file that was almost the same size as the square LED elements. I used GOOP to hold them, and the wires in place. After the GOOP dried I used Gorilla Tape over the back side. I also used the waterproof amber strips for side markers.
The Super Bright strips are 3X brighter than the standard strips, The 12 white LEDs on the front are enough to actually drive BY the light, not just using the lights for reference. Way more than I expected!
Here's some daytime shots, and a short video- http://vimeo.com/45616559
redshift 07.13.2012 01:45 PM
1 Attachment(s)
The underside...
magman 07.13.2012 08:16 PM
very cool! You could also do some at the roof line for xtra white or even amber lights
_paralyzed_ 07.13.2012 10:23 PM
Oh man, I've been seeing LED's everywhere. I'm going to have to start brightening up my rides.:yes:
Looks good redshift! Should last well.
chrismechanic 07.14.2012 05:58 AM
hi redshift...sorry for your loss :oh:
nice work on the led's i see what you mean, it lights up quite well :intello:
chris
Bondonutz 07.14.2012 09:50 AM
My condolences to you sir.
The LED's look great and uber bright !
brainanator 07.14.2012 10:50 AM
I got a few strips of the normally bright LEDs from HobbyKing for my quad copter. MAN these are bright! I can't imagine how the brighter set you have looks.
redshift 07.14.2012 12:37 PM
Thanks guys
So far the changes are the MM, BEC @6V, 4000KV G-Force motor and 3S 4000 mAH 40C packs. Gonna look into a swaybar kit and a better steering servo too.
Magman I wanted to keep the wiring simple and have the lights in the best protected areas on the body. I could always add a few dozen more lol...
Brain, I've only seen the super brights available in white and red so far, but they are insanely bright, even the video does not do them justice. Can't wait to see what they come up with to 'outshine' these!
