-   -   mini revo batteries (https://www.rc-monster.com/forum/showthread.php?t=31460)
_paralyzed_ 07.25.2012 09:14 PM
mini revo batteries
Can anyone give me links to hobbyking packs (3s) that will fit in a mini revo?
or at least give me what dimensions I need to consider?
I'm trying to help a friend.
Thanks for any help.
hashemio 07.26.2012 02:12 AM
The battery boxes for the 1/16 Revo are 101.9mm x 35.5mm x 20.3mm but the actual usable space is only about 90mm long because of the way Traxxas designs Revo battery boxes to taper off at a certain point.
I use the Traxxas ones and they work and fit perfectly but if you want to cut costs, HobbyKing would work too.
I looked on there for you and I found the perfect battery that they make specifically for that truck!
http://www.hobbyking.com/hobbyking/s...6_models_.html
_paralyzed_ 07.26.2012 06:18 AM
Thank you!
JAILBIRD 07.26.2012 05:24 PM
I use the nano-teck 2200mah 35-70c batteries in my mini summit. They fit the box, but I did have to trim a bit off the door for the wires to exit.
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
