-   -   5ive-T conversion question?? (https://www.rc-monster.com/forum/showthread.php?t=31500)
millzee 08.14.2012 10:05 AM
I have bought a 5ive-t and as much as I love driving this thing as a gasser, my wife hates it more than the others, my son's run as far as they can and I have a hard time not driving it out of the backyard to go for a walk, it's bloody heavy to carry across the road, lol.
I've been reading up all day thinking I'd like to try fitting a neu 22series motor in so I won't have heat issues on long bush walks and trying to run it on 8s through a castle XL2, will this motor be too much for the speedo? I'd hope to go this way as I just can't bring myself to spend $700 on a mgm speedo unless it's a given that the xl2 won't handle it. Thanks to jony nitro I now know the rcm mount will work so thats helped a tone, cheers and great build. One more question is what rpm range am I shooting for with this truck with my goal being decent speed and not sacrificing too much runtime. I wouldn't suppose anyone might know if the skopod mount with the rear support would fit a 2220-25?
brian015 08.14.2012 12:40 PM
If you are willing to keep mechanical brakes - you could run a 12s boat or airplane controller. The main advantage over the XL2 is you could run higher voltage/lower current with the proper motor kv and gearing - lower current being better for the esc. Eliminating motor braking should also lessen the stress on the esc.
If you decide to go with an airplane controller, you'll need a pistix to use your ground tx/rx (PM me if you end up needing a pistix - I have a couple laying around here somewhere).
millzee 08.14.2012 07:12 PM
this is just a brain fart but what if this truck was set up like a hpi e-savage with twin brushless motors, how'da recon that'd run, eg.2x 1717's although I'd need to do something about the 5mm shafts and pinions. Maybe a couple of leo 5698's 835kv's/910kv's, does anyone else think a set up like this will take the stress of breaking, I could run either 2x mamba monsters or 2x xl2's and use the dudes 1717 xxl motor mounts, one on each side of the spur, what'da you guys think?
Arct1k 08.14.2012 07:59 PM
Honestly I think 8s, xl2 and 2028 would do fine unless you want to run over 60mph all the time.
millzee 08.14.2012 08:34 PM
cool, that'll do the job for now, anyone want a losi 26cc stock motor with a vrc ceramic pipe cheap!!
Arct1k 08.15.2012 11:21 AM
I always recommend the cap pack and a BEC pro...
millzee 08.15.2012 06:12 PM
thanks mate, I ordered a Bec pro and have a few etti cap banks in the cupboard if they are needed, I appreciate the advise.
