-   -   1/8 GTP geared for high speed. What ESC settings for MMM? (https://www.rc-monster.com/forum/showthread.php?t=31534)
Bmr4life 08.30.2012 07:32 PM
I got my Ofna Late Model geared for 135mph with a 2200kv on 6S. When trying to take off the car goes very slowly, but if I'm not careful with the throttle it will spin the tires. What settings should I use to get smooth take offs that are proportional to how much throttle I'm applying? Should I set it to High power take off?
Bondonutz 08.31.2012 07:30 PM
Maybe the Torque Control will help with your take off issues ?
Post video !
Bmr4life 08.31.2012 08:35 PM
I'll have to look into that. As for a video, I'll try to make one this weekend but I first have to figure out how to keep it on the ground. It blew over something fierce today, was probably doing 90 at the time. Landed on its lid and broke a rear body mount which has since been CA'ed.
phildogg 08.31.2012 10:49 PM
If you are running the rear wing try taking it off. will help with blow overs.
Bmr4life 08.31.2012 10:55 PM
Yeah, I just took it off while fixing the rear body post. I also lowered the front body mounts one notch. I'll get some video tomorrow and strap the gps on.
Bmr4life 09.01.2012 02:13 PM
I tried 5S this morning, the issue is still there.
http://www.youtube.com/watch?v=c5BUC...ature=youtu.be
bdebde 09.01.2012 08:54 PM
What firmware version are you running on the MMM? Did you update it recently? Is it an older MMM? Maybe try an earlier version of firmware.
Bmr4life 09.01.2012 09:08 PM
Yeah, its up to date. Not the newest Beta, but close to it.
magman 09.01.2012 09:42 PM
I run an older firmware in my mmm....works much better. 1.24 I believe
Bmr4life 09.01.2012 10:02 PM
I'll check it and switch to 1.24 its if not. I think I'm higher than that.
magman 09.01.2012 10:20 PM
I had issues when I did an upgrade a yr or so ago so I went back to old firmware and no issues
Bmr4life 09.03.2012 12:34 PM
It was the firmware. I was running the newest which is 1.32. Bumped down to 1.24 and its good. Thanks
bdebde 09.03.2012 12:53 PM
No problem....now go break the sound barrier with it :lol:
Bmr4life 09.03.2012 01:55 PM
1 Attachment(s)
Yeah, that's going to have to wait yet again. I blew the tires off. Belted ofna's suck. There's a guy on youtube that went 129mph this month on GRP's so I just ordered a set of those.
