MBX5T Speed calculation
I need some good guesses on the top speed on a Mugen MBX5T. Its a standard 46/13 gear ratio on 5000 mah 30c 6s. weight is 10 lbs. tires are 4" diameter. 2200kv Castle brushless.
I just ran #'s through the calc...w/your setup using a 13t pinion you are looking at 32mph, w/a 18t pinion you are looking at 44mph. The only issue is the motor RPM which is spinning over 43K which is too much IMO if you want the motor to last.
On a 6s setup a 1300-1500kv motor is best for longevity and good performance. If pure speed runs are what you are after, well then that's a whole different setup. Just my 2cents worth |
You said you were using a 4" tire....seems awful small for a truggy considering my badlands are 5"+ |
Castle, HPI and Traxxas all say the 2200 is fine on 6s, although higher rpm than I like for off road, I think it is fine on road with proper set up. I ran a 2200 on 6s in an Ofna GTP geared for about 55mph, it was a blast... smoking burn outs that left black marks on the road.
so...w/a 13T = 42 18T = 58 Again, the motor would be spinning at 43K |
| All times are GMT -4. The time now is 06:01 PM. |
