-   -   Old drift buggy back in commision (https://www.rc-monster.com/forum/showthread.php?t=31747)
tha5150 01.30.2013 08:49 PM
Been packed up for close to 4 years. Pics below. Was a drift setup but in all honesty I paid and a friend built. Plus the 4 years have only added to my lack of knowledge.
Here goes. Looking to transform this into a street car and not a drifter. Looking for Spur and Pinion gear advice and of course, tires. I would like to peel out a little bit but still grip on turns. Not on a track, just in the street.
Havok 8.5 - http://www.ehobbies.com/nov3038.html
On this car setup, what is my Pinion and Spur setup when using top of the line 4600MAH batteries when not trying to fry anying?
https://lh5.googleusercontent.com/-r...151046_337.jpg
https://lh3.googleusercontent.com/-9...151106_676.jpg
https://lh4.googleusercontent.com/-J...151122_537.jpg
https://lh6.googleusercontent.com/-7...151134_820.jpg
https://lh4.googleusercontent.com/-l...151144_039.jpg
https://lh4.googleusercontent.com/-s...151200_825.jpg
https://lh3.googleusercontent.com/-a...151217_236.jpg
tha5150 01.30.2013 09:00 PM
TC-4.. Not buggy, sorry about that. I have another buggy I am making a post about also.
KMN 02.16.2013 12:17 AM
I still run TC-3's.... bought one brand new back in 99' or 2000..... Essentially the same car.
If I recall, I haven't checked it in years, but I run a 4600KV setup on 2S with a 69T spur and 20T pinion. Nothing ever gets hot, and it's an OG Castle system. I have been running it that way for over five years now and just run the piss out of it.
http://farm9.staticflickr.com/8317/8...051873ef_c.jpg
tha5150 02.17.2013 12:03 PM
Sweet setup.
Was running the other day and no more rear power when on the ground. If I pick it up then the rear spins. Did I burn something up? All because of the new street tires lol
KMN 02.19.2013 09:29 PM
If it's not clicking, it sounds like a ball diff let loose. If it's clicking, you stripped a ring or pinion.
tha5150 02.19.2013 09:36 PM
No clicking.where do I tighten?
KMN 03.02.2013 09:09 PM
You can get a 2.5mm allen wrench in one side and see if tightening it up helps. There's a bolt that goes through the diff and holds the balls, spring, washers, and d-rings in place. If that gets too loose, the diff will slip.
tha5150 03.04.2013 03:03 PM
where at in this photo??
https://lh3.googleusercontent.com/-_...151036_542.jpg
traxxasbasher13 03.04.2013 06:34 PM
Originally Posted by tha5150 (Post 426186)
Its going to be inside one of the out drives of the diff. I couldn't tell you which side though, its been years since I messed with one of these. Just pop off the top ball cups and check each side, tighten it until it drives like you want it to. If it won't tighten enough, its time for a rebuild.
tha5150 03.05.2013 10:46 AM
thx!
KMN 03.08.2013 09:36 PM
Long outdrive side, so it's going to be on the left hand side of the rear, and the right hand side of the front. If I remember correctly....
tha5150 03.09.2013 03:26 PM
got it. problem solved. thanks guys
tha5150 03.09.2013 03:30 PM
does this link work for you guys? if so, how much should i sell everything in these 52 pictures for?
https://plus.google.com/photos/11771...CI6w7KXSpLnmDw
brainanator 03.09.2013 03:46 PM
Link works fine. That's quite a bit of stuff for us to give a price on. Your best bet is to add up the total it currently costs new, and knock it in half (or more/less depending on condition). Great condition can go for up to 80% of new, pretty beat up can go down to 25% or even worthless.
tha5150 03.09.2013 03:58 PM
Thanks.. I will try to find a price. Going to be hard lol and time consuming.
