Brushless help
Mike, Will the 1950 fit into a pan car with 3800mah 4cell battery? is it 540 size if not i need a speedcontrol and someting fast. i run 6a six single now with 3800mah batterys.
The 19 series is the same diameter as a 540 motor. The 20 30 40 and 50 part is the length. If a 74 mm motor will go in your car it will fit. It has some awesome power though. I have ran a 1930 in a emaxx with no problems.
a 1950 will most likely not fit into a pancar its just to long and it also wont due well at all if you plan on running one 4 cell pack.
By the way welcome to the forums |
It would depend on if lipo or nimh/nicad. The 4 cell lipo would be plenty for a 19 series.
i was thinking of a 4 cell nimh pack
what kind of pancar do you have? i know that a 1950 would not fit in your standard 1/10 scale car without some serious modification it is just to long |
pancar
I have a Ksg,Rip Motorsports,Customworks pancars. We run 3800 nimh batterys need a speedo and a super fast motor to run Mod 4cell. Thanks all the help.
I think you best bet on such a low cell count would be a Lehner 1920/4 High Amp. It has the highest kv I could find, which you need for only 4 cells.
What kind of cells you run? nimhs nicads or lipo type. ARe the 1.2 volts a cell or more.
Coolhand, he said nimh in post #6.
Gee wizz. I got to be blind or something. 4 nimh cells is not much juice.
even if it did have good power it'd be too much for the wheels
i agree with squee in the 1920/4 hiamp. it would probably be the best motor unless you wanted to go with a smaller 15 series motor
| All times are GMT -4. The time now is 02:30 AM. |
