Wr8 body on Ten-T
Anyone with experiance with the Hpi wr8 and the Losi ten-t?
Curious as to wether or not the body would fit, Wheelbase seems to be the same spec wise, Width is going to be wider on the Ten-t and Wr8 is going to be a bit longer Curious as to how wide a ten-t would be with buggy wheels or even wr8 wheels. I know everyone is familier with the ten-t but am providing sites for both anyhow. please delete links if i am in the wrong. Thanks in advanced guys. Wr8 Ten-t |
Wow. We are dead here.
I'm not familiar with either but a quick look at the links you provided shows that it wont work, the wheelbases are right with 300mm and 298-301mm, but the widths are wildly out with the rally car being 227mm wide and the truggy 342mm wide.
I guess if the truggy's tyres are less than 57mm wide you could technically fit the body on the chassis with the wheels on the outside of it, but the WRC car / Monster truck mix achieved by doing so would look very silly in my opinion. I was going to suggest a 1:10th buggy base instad of a truggy but while being closer, they arre still much too wide at 250mm. |
| All times are GMT -4. The time now is 09:43 AM. |
