G4 Widetrac Build
Turns out my chances of owning a G4 anytime soon were not as low as I had been thinking!
http://www.unlimitedengineering.com/...e1_284645.jpeg http://www.unlimitedengineering.com/...e2_667535.jpeg http://www.unlimitedengineering.com/...e3_592722.jpeg So, now that I have one, I've sorta switched gears on one of my other builds. I had been collecting these parts to build a front and rear end for my HVL...but I've decided to use it all on my new G4 (so I'll need to begin collecting a new setup for the HVL soon) http://www.unlimitedengineering.com/...e1_531166.jpeg http://www.unlimitedengineering.com/...e4_856727.jpeg Drilled & Tapped the GA Bulkheads for Ejector Pins http://www.unlimitedengineering.com/...e6_489131.jpeg http://www.unlimitedengineering.com/...SetScrew2.jpeg Modified a rear sweetstrobe brace to work with gumleguf's large wing mount http://www.unlimitedengineering.com/...e3_301764.jpeg http://www.unlimitedengineering.com/...e2_317692.jpeg http://www.unlimitedengineering.com/...e5_738182.jpeg -Travis |
http://www.unlimitedengineering.com/...e7_776998.jpeg
http://www.unlimitedengineering.com/...ge8_92064.jpeg http://www.unlimitedengineering.com/.../image345.jpeg And here's where I'm at with the build right now. All I need is set of Ultralite Diffs and I'll have a roller! :party: http://www.unlimitedengineering.com/...e4_221214.jpeg http://www.unlimitedengineering.com/...e6_755842.jpeg http://www.unlimitedengineering.com/...e5_904102.jpeg -Travis |
The G4 has been monoblock'd.
It had to be done. Just didn't look right without it. Plus, the rear center bone that I got with the chassis is made for use with a mono, soo.... I guess it had to be done :sarcastic: lol Took some careful dremel work (didn't turn out perfect, but not bad for being done by hand) http://www.unlimitedengineering.com/...ge1_61178.jpeg http://www.unlimitedengineering.com/...e3_963507.jpeg http://www.unlimitedengineering.com/...e5_385722.jpeg -Travis |
Awesome build! :yes:
Thank you sir
Got this purdy new shell for it in the mail over the weekend :yipi: http://www.unlimitedengineering.com/...ge4_42125.jpeg http://www.unlimitedengineering.com/...e5_735554.jpeg -Travis |
5/16" Aluminum round stock for custom body posts
http://www.unlimitedengineering.com/...e1_433442.jpeg And some aluminum set screw collars http://www.unlimitedengineering.com/...ge2_94809.jpeg They ended up a little long, so I need to cut them down still http://www.unlimitedengineering.com/...e3_824456.jpeg http://www.unlimitedengineering.com/...e4_769908.jpeg http://www.unlimitedengineering.com/...e5_993137.jpeg -Travis |
Thanks to Justinbolin, I have a purdy new servo saver for this truck :mdr:
http://www.unlimitedengineering.com/...e1_969325.jpeg And because I like to make what I already have work (and because I'm too impatient to wait for parts), I modified a set of TRX 7075 Tie Rods for the front. I removed the double threaded ends, tapped the tie rod tubes out to 8-32 to accept some cut down ss screws so I could attach the plastic rod ends. By eliminating the original double threaded ends, I was able to shorten the tie rods just enough for them to be the perfect length. http://www.unlimitedengineering.com/...e2_604790.jpeg Now I just need to de-anodize them so they match the rears. http://www.unlimitedengineering.com/...e3_761047.jpeg -Travis |
Checkout Lunsford grinder Ti links - They look much better and are much stronger.
I hadn't seen those before, but you're right, they're nice and clean looking.
I will probably stick with the TRX aluminum ones for right now, just because they work and they should be pretty stout...and I have plenty of electronics to spend $$ on first, haha -Travis |
One Comment and two questions:
Comment: You have built and absolutely amazing truck, even if you didn't buy the knuckles from me, lol...but seriously, it's gorgeous! Questions: [1] Did you make/mill that wing-mount for the new MBX-T Wing yourself, or did you buy it somewhere? If you boight it, where? [2] I guess this is more than 2, heh...you did and damn good job modifying that Mono-Block for the G4 Chassis. |
I can possibly answer one of your question's
http://www.unlimitedengineering.com/...ad.php?t=23747 http://www.youtube.com/watch?v=vOKCwk1nRCI |
Chad, thanks for the compliments on the truck!
CerberusVI got the wing mount question answered for you. And thank you on the monoblock mod, it took me a while to do, but it fits perfectly! -Travis |
Well, the original center diff mount plate I got with this chassis was pretty thick, and stuck the RCM mount up high enough to cause the rear bone to interfere with Gregers' custom G4 brace. So, I robbed the center diff mount plate I'd originally made for my Predator truck (before I got one of Gregers' custom center diff mount plates, which I am now using on that truck), and I modified it to work for this truck, as its about 1/4 the thickness of the plate I got with the G4, and lowered the diff down where I needed it to be for the rear bone to clear the center hole on Gregers' custom brace.
http://www.unlimitedengineering.com/...e4_455369.jpeg Cut the plate down a little so it fit in between the two chassis braces http://www.unlimitedengineering.com/...e5_337236.jpeg However, it turned out using the thinner plate was still not enough. The RCM mount was still sitting a little high. So, I cut about 4mm or so off the bottom of the RCM mount legs to bring the diff down even farther (and I slipped some stainless steel 16mm shims in to take the slop out of the diff) http://www.unlimitedengineering.com/...e9_909594.jpeg http://www.unlimitedengineering.com/...e12_41863.jpeg And since I cut some material off the RCM mount legs, I had to add a slot for the spur to stick through the bottom http://www.unlimitedengineering.com/...e2_513991.jpeg Drilled some mounting holes in the chassis for the new plate http://www.unlimitedengineering.com/...e5_304614.jpeg And mounted it all up http://www.unlimitedengineering.com/...e6_872816.jpeg With the center diff mount much lower, the bone now clears the top of the custom G4 brace http://www.unlimitedengineering.com/...e6_474579.jpeg http://www.unlimitedengineering.com/...15_615636.jpeg -Travis |
Awesome! Too many people are so a-scared to modify their parts. You just gotta man up and do it!!! In this case, Wheelman up and do it!
| All times are GMT -4. The time now is 09:00 PM. |
