Castle on/off switch
Greetings,
Took a big hit and lost power to my controller. Turns out the on/off switch wire mounting pin separated from the board. Is there any way of reconnecting the wire to the board sans the metal tab it usually solders to. Thanks. |
Edit; sorry, misread your post.
Pics have you destroyed the solder pads?
If yes - toast.. |
unfortunately yes...is the heat sink removal? maybe to reconnect from the top side.
I doubt it as its s multi layered board. Looks like its s $70 repair.
Time for a XL2 upgrade. Might get it gone for another car I have waiting.
| All times are GMT -4. The time now is 04:42 PM. |
