Adding a cap
I have two blown novak HV maxx escs. I would like to remove one of the caps and install it on my mamba max (not pro) esc. I just installed an external bec to help keep temps down. I have read caps can help too. Seems pretty straightforward to me.
I just want to make sure, is there anything special I should know? Such as solder the cap wires near the esc or the battery plug? Or anything else? Thanks guys. |
Also, I have read the mamba max is capable of 4s with an external bec. Is there truth to this?
I have run many that way for years.
4s with an external bec? Good to know. I've been thermaled on 2s running a 5700 2 pole. Looking for ways to handle this 5700 motor a little better. Last few runs went very well, even a 3s run.
Still wondering about addint a cap... Should it be discharged first? I have one that's been out of use for five years. It's most likely naturally discharged by now. |
| All times are GMT -4. The time now is 09:04 AM. |
