-   -   Tekin T8 Wiring (https://www.rc-monster.com/forum/showthread.php?t=32017)
Kcaz25 12.01.2013 09:17 PM
Tekin T8 Wiring
Hey I am getting ready to try sensorless. I am trying to order a Tekin 4038 T8 2000kv
Let me know if you have one and would like to sell. I would really appreciate it!
I need to know if the tekin motor tabs can be easily and safely connected to with wires directed straight away from the motor just like a Castle 1515. Thanks!
-Zack.
BrianG 12.02.2013 06:24 PM
I'm not selling one, but not quite sure about your other question. With sensored, wire order matters (to be in sycn with the sensor wires), but with sensorless, it doesn't matter. And yes, soldering the wires to the tabs is easy to do - and safe if done right.
Kcaz25 12.02.2013 06:38 PM
Thanks Brian. I mean pointing them away from the motor. All the pictures I have seen are of the wires pointing inline with the motor.
Thanks,
Zack
BrianG 12.02.2013 07:57 PM
Well, it's generally easier to do it that way.
For one, the tabs are a little longer than they are wide so it's natural to lay the wire on that way.
Second, soldering them perpendicular to the motor will cause the wires to overlap (obviously), thus are more difficult to solder (but not impossible). Also consider that any overlapping wire will have wear on the insulation from the soldered joint beneath it caused by vibration/movement and may eventually cause a short (not good for the ESC). The only other option would be to solder the wires "on-end" to the pads, which can be even more difficult and result in less contact area.
Personally, I'd just solder the wires inline to the motor and just give yourself an extra two inches or so or wire to allow the wires to loop nicely where they need to go. Kinda like how the wires on my Ten-T are arranged:
http://www.scriptasylum.com/bl_conve...es/ten_t_1.jpg
If that extra looping gets in the way of a-arms or whatever, consider making a bracket and zip-tire the wires to keep them secure.
Kcaz25 12.04.2013 08:23 PM
I am routing the wire underneath the rear center dog bone. It will feed straight across to the ESC.
I found a 4038, so I no longer need a motor.
Thanks,
Zack
