6.5mm Bullet Connectors Don't Fit
I bought the CC 6.5mm Bullet Connectors to a make a lead from my 1515 2200kv to my ESC with 4mm inputs. The males cannot enter the females no matter how hard I push. The male connectors on the motor cannot fit into the female connectors either. Pinching the motor's connectors didn't help, either. I'm 255LBS so I'm no scrawny dude. All the male connectors are too big for the female connectors. I have lots of CC motors and ESC's with 4mm bullet connectors, and I've never encountered this problem. Is this normal with CC 6.5mm hardware??
Maybe you warped them while soldering.
I haven't soldered anything. This is fresh out of the package. I just test fitted, and it's a no go.
Hang on, your 6.5mm bullets don't fit in 4mm sockets, and you're surprised?
Unsurprisingly you need 4mm bullets to fit in 4mm sockets, or 6.5mm sockets to fit 6.5mm bullets in. |
I guess the same thing has now happened with the 6.5s. Contact Castle and ask to have them replaced with ones that are test fitted before shipping. When I called them to get my bad ones replaced, about half the new ones still didn't fit. |
Ja, I had bad 4mm too a while back. I just got a batch of 6.5mm and some are too loose. Different problem I guess.
| All times are GMT -4. The time now is 08:48 AM. |
