bore reducer 8mm to 6mm
Hello
Where can I buy bore reducer 8mm to 6mm motor shafts ? |
I actually don't make one for 6mm shafts(everything is to 5mm shaft) - I could make an aluminum reducer pretty quick for a 6mm shaft, though. - what is the application?
like this motor mounts http://kershawdesigns.com/Kershaw%20...-InstallHD.jpg I want 8mm reducers Mod1.5 pinions to be used with 6mm output shaft. Can you help me please? |
| All times are GMT -4. The time now is 12:41 PM. |
