Sidewinder 8th feedback
Looking for any comments, concerns, etc. about the Sidewinder 8th.
Anybody here tried it? Thank you! Patrick del Castillo Castle Creations |
I have been thinking about trying one... any one else tried yet?
Was really hoping to get some feedback here...
This is really a nice ESC and is almost a direct replacement for the Mamba Monster. Please post your experiences here. Thanx! Patrick |
Was hoping for some feedback too.... guess I will have to be the guinea pig!
I have one, something is wrong with the start power and I just shipped it in. It ran perfectly at speed (above 3mph or so) but below that there was barley enough power to get the truck moving, much less spin the tires as it did from 3-20mph easily. It did this with two motors.
And I dislike the removable RX wire...I had to bend the pins around and use a zip tie to hold the wire and get it to make a good connection during a run and not come unplugged... I'm sure the first problem was an error in manufacturing on mine, as for the second, i'd rather have a female rx plug than the three pins that fit too loosely Fix those two things and it'll be golden |
Hadn't seen any issue with the removable RX wire yet -- that's interesting that you are seeing it come loose. I'll have the engineering team here look at that and see if there's anything we can do to fix the issue on this side. The start power issue is probably just that -- start power is set too low for your particular motor. Have you tried bumping it up? Thanks! Patrick |
The removable rx wire would be a defect in the thickness of the pins or inserts in the wire plug, It was also one of the first run ESC's i think to where the problem may have been fixed already. I solved the wire problem by bending the 3 pins different directions so they hold pressure and then used a zip tie to prevent it from coming loose |
Thanx! |
Not avalible in germany yet,
but as soon i have it i'll post my feedback |
And back to the wires pulling out, you guys already fixed it, the new version has tabs to clip the wires in, my first one only had the friction of the pins fitting into the slots holding them in. Here is the new one: http://i101.photobucket.com/albums/m..._58_21_Pro.jpg Quote:
esc looks good. lmkk how it runs. I might pick one up for slash 4x4.
| All times are GMT -4. The time now is 06:27 AM. |
