Regular diff oil wt vs slipperential oil wt
So...easy question. Do I run the same weight of oil in the slipperential as I run in my regular diff - or does it need to be thicker/thinner?
The same oil can be used. Internally, the diff is still a diff.
Ok thanks. I didn't know if the slipper function made it necessary to run a heavier or lighter weight oil to have the same handling.
The slipper works independently of the differential - if you run a LOT of slip you may go slightly heavier, as slip generates heat. I use 5k in my buggy and 10k in my truggy with the Slipperential - same as I used to use with a regular diff.
Perfect. Thanks for the answers!
| All times are GMT -4. The time now is 08:26 AM. |
