E-lst 2 project xo-1 1717 mm2 6s
Getting it together but need ideas for pinion size not for high speeds or crazy torque lookin for cool temps and good runtimes help me out been reading a lot but forgot because everyone has a different setup
Most people use a 25 tooth pinion and a 63T spur if I am correct.
Got a faulty 1717 had a rattling noise for a new product and now im thinking tekin 1700kv or 1400 kv
I have a custom set-up where I am running a 26/51 combo...fast as stink and torque happy. Running a Big Block Mamba from a XO-1. Check out the following thread.
http://www.rc-monster.com/forum/showthread.php?t=32095 |
How did u lower ur stance and have u fixed ur lst2 from the crash if so how fastate
Does ne1 know how to mount the 2 gear pinion clutch bell to a brushless motor becuz I have seen sum people with it on a brushless just need a link or something
Thanks out of stock but found it on ebay
Brushless Losi,
Yeah, I got my Losi back on the road. Hitting a tree and plastic does not mix. I reassembled the rear end and all was well. I dropped the stance using some leftover carbon plate glued together. Here is the thread that had the drop blocks in it. http://www.rc-monster.com/forum/showthread.php?t=32095 |
Should I mount the rx next to esc or servos which causes interferance I have the rx8 t8 and mm2 and 1515 what are the rules for mounting a 2.4 tx
In one of my models, I never had an issue mounting the reciever atop the servo.
Just got the tekin becuz I got another effect xo-1 1717 it would prolly work but was used and I paid a high price but was wondering if tekins are easier to turn the motor by hand than castles becuz it seems like it is like butter compared to a 1515 2200kv which is kind of hard is ur xo-1 motor hard to turn by hand
| All times are GMT -4. The time now is 09:02 AM. |
