Sidewinder LVC kicking in when LVC disabled?
I was doing some testing with my new crawler and a sidewinder sv2 in brushed reversing mode.
3s 2200mah ~3.75v/c starting voltage(storage charge) Lipo cutoff was disabled After 2-3 min the esc went into LVC(green/yellow flashing). Unplug/replug and it worked fine for another 2-3 min. Verified with CC link that LVC was disabled. Turned LVC on at 4v and ran for 10-15min without issue. :neutral: |
Thanks! Patrick |
I did some more testing with it. The problem seems to be related to reverse. I could drive forever going forward, but only backwards for a short time before the esc would LVC.:neutral: |
| All times are GMT -4. The time now is 08:45 AM. |
