Are these for the LST1 or LST2?
Hello,
I need help from someone who has seen both the LST1 and LST2 steering knuckles. I am searching for aluminium ones for a while, and came across these: http://www.hot-racing.com/index.cgi?...=LST2108;c=160 They say they are for the LST LST2 and Aftershock, but that is not possible because of the difference between the LST's. LiquidRC advertises them as for the LST and Aftershock, and the outer hole looks a bit to small for an 8mm axle and a bearing? But the part number suggests it is for the LST2? I do not think it will fit, but just to make sure, can someone help me out? I have not seen the LST1 knuckles good enough to see the difference, but I do know that the holes in the GPM LST2 knuckles look bigger on the picture? Thanks in advance! Ruud |
Hi Ruud
Yes you are right they will only fit the LST;( the LST2 one are alot bigger! hot racing do make one for the LST2 as well but as you no every thing is out of stock for the LST2 unless you are lucky to find some thing you need;) hope this help you out Ruud i am still looking to if i fine any i will let you no;) Thanks WEB |
Ok, thanks for the info!
Same here, if I find something I'll post a link here! Sucks that they are out of stock everywhere, they are the only parts I break with my Muggy. Or could that be because I use aluminium spindles? The parts that hold the steering knuckles. |
I just saw that Losi makes them to right now for the LST XXL series!
I hope the aluminium is better then the aluminium used on the top plates etc. http://www.bigsquidrc.com/losi-alumi...the-lst2-xxle/ Not that expensive either, I am gonna order then asap I think. |
| All times are GMT -4. The time now is 01:29 PM. |
