Rustler setup - am i on the right track?
Looking at:
warrior 7020 fiegao 380c - 6T running on between 6 and 9 cells. Looking for a fast little rustler, I have been running 7 turn motors and its just not enough so hoping this will blow my wig off, fit in ok, use standard pinions? not overload the speedo? Rene im looking in your direction! |
I think it should be fine! But if you havent ordered yet, you could get a Quark 80B controller, those look like nice controllers, or an MGM would be great, too! But if you want a BK, the 7020 will be fine. P.S: If you like to be super safe, a 9920 would always be better!
i screwed up, i meant 6T. Im ok with the warrior unless the others are much cheaper, this is just a fun/bashing setup.
You mean a 540 6t. I have some of the guys like the 380c motors more than the 540 6t.
i thought the 380c would be better in the rusty?
It would be ok, but not better than a 540 can. It will run alot cooler, for sure!
ok, so are we revising to a fiegao 540s 6T? does this have a 1/8th shaft?
I was thinking given the low cell count (6 - 9 cells) the smaller motor would give more speed. |
I think the 380C is a better choice. The 540 6s is an amp SUCKER.
The Warrior 7020 may not be up to handling the 380C 6t. It's a hot motor. The MGM Compro 80amp or the Quark 80amp should both be capable of handling the motor, and are much more adjustable than the 7020. |
im trying to keep to a budget really (around $200), how a bout a slightly cooler wind?
So the rustler needs to be punished again!?
Why not take an feigao/wanderer 8S? i like it in my rc10t2.. It runs nice on 7 cells. it has got tons of torque and on 3S lipo, it pretty much reminded me of my mamba 8k in my mini-t.. (but that's 3S lipo) The small little rotors in the smaller motors spin up pretty fast though (that 380 sized thingies) , My guess is that an 8S would act less nervous The 6T is too hot imo. I can guarantee you that you'll love the 8. It runs nice on 6 allready. on 7 it's pretty fast (more than enough for a track) and on 9... well on 9 i can't imagine nothing but fun.. |
with my e-maxx, the XL2400 draws a peak of 70a, and that's with 3S lipo and on a heavier truck. (the 7020 can handle more than the peak of 70A though)
It uses a 3.2mm shaft (1/8th) |
ok so im getting warrior 7020 and 8s wanderer, good good
Sounds like a plan to me..
Good thing about the 7020; BK offers an upgrade on them.. (till a 12020 or a15020) |
I thought they offered to upgrade to a 9920 12020
They do. Just only up to the 12020 or 15050. Remember, the Wanderer motors all have a 5mm shaft. You might need a Feigao.
| All times are GMT -4. The time now is 09:23 PM. |
