-   -   My 'Pede needs BL power... (https://www.rc-monster.com/forum/showthread.php?t=3330)
blasterak 06.14.2006 03:07 PM
I was thinking of gettin an Mtroniks Pro and a 6L and run it on 3S Lipo. About what speeds would I be getting w/ this set up? And what gear should I run? I am also thinkin about the 12s after I read someone got up to 57mph on it, that is some insane speeds and that what I want, could the 6L do that? Anyways thought Id put up some pics of my pede, it has some FLM parts and the usual upgrades it has a dogbone conversion, going to see how that works out. I run nitro rush arms up front to line up the rear w/ the front and run wide offset rims all around, still waiting on some big bore shocks for it...
http://i35.photobucket.com/albums/d1...k/000_1200.jpg
http://i35.photobucket.com/albums/d1...k/000_1201.jpg
http://i35.photobucket.com/albums/d1...k/000_1202.jpg
http://i35.photobucket.com/albums/d1...k/000_1203.jpg
http://i35.photobucket.com/albums/d1...k/000_1205.jpg
SpEEdyBL 06.14.2006 03:51 PM
3s lipo might be a little too much for the 6l, and thus it will heat up quite a bit, but I'm sure it will be able exceed 50 mph.
cart213 06.14.2006 04:10 PM
I agree that 3s may be too much for the 6L. The bad thing about that motor is that it's kv doesn't match up with lipo very well. 3s is too much, and 2s is too little. 8 NiMh cells at 9.6 volts would probably be ideal.
With that said, I run a 12s with 12 NiHm cells or 4s Li-ion, and it is FAST! Over 50 mph with no overheating so far.
blasterak 06.14.2006 04:57 PM
Ya I see what your saying. I guess I can run it on 8 cells im going to go lipo but ill still have my gp cells to run in this. Thanks guys I'll be ordering up the 6l soon then.
MetalMan 06.14.2006 06:47 PM
You'll have no problems with the 6L on 8 cells.
BTW, I'm the one that's been advertising the 12s hitting 57.5mph :).
blasterak 06.14.2006 06:56 PM
On top of that an 8 cell flat pack fits perfect on the chassis. I just got done converting all my packs to 8 cells.
MetalMan 06.14.2006 09:56 PM
Even better :).
Bmr4life 06.15.2006 12:39 PM
Your stampede looks just like a rustler sitting low like that. As a matter of fact, I think my rustler is sits up higher than your pede. :D
cart213 06.15.2006 01:17 PM
And I plan to beat that speed when I strap on my emolis soon, travis. :005:
blasterak 06.15.2006 02:01 PM
Ya I like it sittin low, but its just a matter of moving the shocks into different positions to have it sit like a monster, thats the beauty of FLM shock towers and arms.
Bmr4life 06.15.2006 02:04 PM
Yeah, I like the FLM arms to, but mainly because they widen the front and rear while making them both equal at the same time. I've yet to bend one, but they have caused me to break a lot of other weak points.
blasterak 06.15.2006 02:36 PM
Ya true, what gearing do you guys recommend I start with for the 6L?
joostin420 06.16.2006 10:01 AM
i am on par with MetalMan.
i run a 12s, schulze 12.97 controller, and 4s lipo in Nemisis, 19/87 gearing (1/8 rustler buggy):
http://home.comcast.net/~joostin420/...4/site1406.JPG
justin
