-   -   Hurt tranny, what to do? (https://www.rc-monster.com/forum/showthread.php?t=3358)
Bmr4life 06.18.2006 02:27 AM
I ran my E-maxx for the first time with 12 cells on the 10L. About 7 or 8 mins into the run, I blew 8 or 9 teeth off of the high speed idler gear. I see that there are steel idler gears that I can upgrade to, but won't that just cause another gear to strip. I would like to know if there are any other metal gears for the e-maxx tranny? Also, is there an upgraded input drive shaft gear because I've busted the pin in one of those before. thanks
Sneeck 06.18.2006 02:46 AM
The metal idler pretty much make's the gear's bomb proof. Like you said you'll be snapping either those pin's or the complete input axle next.
There is only 1 really good upgrade, and that is the ultramaxxed tranny gear's. But those are rare and very expensive if you do find some. And heavy. I'd get a metal idler and stick a nail thru the input pinion and bend it to secure it.
Bmr4life 06.18.2006 02:49 AM
Thanks, sounds like a plan.
