Which Lipos For 1920/8 and Micro2095
I've been thinking about going lipo, but really not sure...so i figured I'de ask you guys.....I do have a Triton charger. I'm not sure which lipos to use.....right now I'm running 12 cells in series.
motor specs are 3919 RPM per volt |
3S or 4S lipo. It would depend though. Fully topped off 4S will be a little higher and 3S will be a little lower.
But that answer of squee depends on a very important thing;
What car are you planning on using it in? |
my dominator/emaxx hybrid......im running (1) 12 cell NIMH 3300 pack..
I've ran my motor and controller as high as this... 16 cells = 19.2v 1920/8 rpm= 3919 --------------------- 75244 RPM and never even had a problem..... 2095 Micro controller was fine and so was the motor |
4s, then. The Apache lipos which Mike is carrying are good. Team Orion and Peak have a 4200mah 2s packs. You can get two of these and fly.
That's way too high sjcrss, that setup is way too hot imo. those ratings of the motor are under load. you are better of with a higher gearing and a lower kv motor.
That must be very hot,i've got a 1920/10 and i sometimes run it on 4s in a 1800g truck,albeit geared for 60+mph and that get's a little hot for general driving.It likes 3s,35,000rpm,runs very cool on that.
Did it not get extremely hot at those rpms? testament to lehner that it's still going strong. |
| All times are GMT -4. The time now is 05:52 PM. |
