e-maxx brushless recommendations
I am a new e-maxx owner of about 2 weeks and can't quit upgrading............so obviously brushless is the next logical step............i have some nice 14 cell 4300miah packs that are great, just this upgrade has broken both rear cvd, center cvd and rear diff spider gears.............those are now all upgraded to steel and a spool in the rear diff............now my dillema is which brushless system to go with...............I am not a skilled installer or solderer...........i mainly plan to bash so longer run time is an absolute requirement over stock..........but if i wanted to try and do a race just for fun i don't want to get blown away by nitro monster trucks, since in my area there are never enough electrics to have a monster electric class, I would have to just run with the nitro's..........i will say the speed even for the stock motors on good 14 cells is hard for me to control
hv-maxx - pros - easy installation, sensored which will be smooth power when rock crawling type stuff, works well with existing 14 cell packs, pre-wired to the esc cons - not as powerful as some of the sensorless systems, lacks low battery voltage cut-off if i run lipos in the future castle creations momster mamba max - proposed 2000 watts might be too much for me, and seems to have endless launch delays quark, plattenburg, lehner, fiago - i just don't have any idea what would be better and what about each is worth the money........the multiple combinations of speed control and motor is very confusing.....I don't want massive power if my run time is only 10 minutes..........any low speed cogging would just drive me crazy.........any thoughts or recommendations would be appreciated............. |
Well first off, welcome to the forums! I think what you would like would be something like a Feigao/Wanderer 10XL and Warrior 9920 or maybe a Quark 125. The Quark is the best of the 2 but obviously more expensive.
thanks for the welcome........well ok, can you elaborate as to why you think that is a good combo.........if money was no object what would be the best baterry/esc/motor combo available, and why??
I get the sense quark is prob the best esc.........maybe lehneror plattenburg is the best motor ?? would any of these systesm absolutely be as smmoth as the hv-maxx at very low speed ?? |
The Quark is a VERY smooth esc and with an XL motor there would be almost no cogging. However, if money were no object, the 1950/8 on 5 or 6S lipo with a Quark 125 would absolutely be the best.
i can testify to the 1950/8 on 6s lipo. it is very powerful, but i wish i would have known about the quark first. my bk 12020 does ok, but it seems like most of the power is on tap after 3/4 throttle. that makes it hard to control on the track. you can't go wrong with what squee suggested!
ok you got me thinking...........what is actually better between the 1950 and the xl..........also what would this do to my run times ?? I was thinking maybe the 8000 miah 3s lipo from maxamps would be the ideal battery !!
or the speed or another setup such as...Feigao 540c 9XL motor+Warrior 9920 Car Controller... would this be faster than the HVmaxx? |
It would be WAY faster than the HV. The Feiga/Warrior setup is much better.
I appreciate your input but way faster and much better sound inticing, but it is hard to get a sense of how significant the difference realy is ?? Could you by chance offer some real world numbers such as actual top speed difference and actual run time difference ???
I would estamate around 40 mph +/- and about 20 minutes runtime. Both better than the HV.
9,8,7 XL whats the difference between the 3?
9920warrior & 12020 Warrior whats the difference |
What difference are you referring to? Speed? Runtime? Overall? The main difference is how many winds it is. 9XL= 9 winds.
It all depends on the cell count.
| All times are GMT -4. The time now is 09:01 AM. |
