-   GorillaMaxx (https://www.rc-monster.com/forum/forumdisplay.php?f=16)
-   -   Another Pillow ball question... (https://www.rc-monster.com/forum/showthread.php?t=3375)
neweuser 06.19.2006 11:00 PM
When putting them in, there is a small set screw, are you to use lock tite of some sort on this? Or can you jsut put it in snug? thanks!
squeeforever 06.19.2006 11:05 PM
Most just snug it up but I would suggest putting a dab of Loc-Tite on them.
neweuser 06.19.2006 11:53 PM
thanks again, and again, and again!!! LOL, you are always dependable! thanks! really appreciate it!
squeeforever 06.20.2006 08:41 AM
No problem!
neweuser 06.20.2006 10:13 AM
I think i found a problem. My mip's are almost not long enough to the UE drive cups. I'm worried if i adjust the pillow balls in more, it'll start to tweak my turnbuckles, any suggestions?
captain harlock 06.20.2006 10:43 AM
How about using some spacers between the CVD's cup and the bearing to make the CVD go in a bit more?
I think some people were not able to make a MIP CVD work with UE diffs and extended suspension. Probably you may want to get a set of SuperMaxx CVDs from Mike.
neweuser 06.20.2006 10:47 AM
my tranny extended is fine. It's shafts to the wheels. If i use two spacers, it'll help, but not quite enough. If i use more than that, there is binding. Are the UE cvd's longer? I thought they were the same length...thanks!
cabking 06.20.2006 11:23 AM
I wasted a pair of Mip's because of binding, bent them like bananas it did:032:
Can you limit the suspension travel any?
neweuser 06.20.2006 11:29 AM
I'm almost as low as i can get with the gorilla suspension. It's the top of the shaft near the cup that's right at the end. The bottom seems fine and back far enough. Does that help? This is really irratating me, i measured the cups and they are the same length and not sure why these won't fit now! ARRRGGG!!!
