UE CVD's HELP HELP!!!!
I just got my 6mm UE drive shafts. They came with 14mm "hex" wheel hex nuts. The problem is, I run 23mm Proline adaptors on my wheels that are not hexed! How can I make these work? I want to use my 40 eries tires and rims that are 23 mm. Does dace make them so the 14mm hex nut goes inside that? I need help! thanks!
that is what you need. The dace works great with them.
That is the only wayI know of you can do it unless you make your own adapter for it. |
so what your saying is the dace are made for the 14mm go inside the 23 mm adaptors? I'm running the cheyenne rims. but the UE have the hex end not the pin set up...
Yep, you need the dace. You should have got those in the first place!
Yep i know! that's what i get going cheap! twice burned! got MIP, didn't fit, got proline..didn't fit! Ebay, here i come to sell!!!!!!!!!!!!!!! OK, just to clarify one more time! the 14mm UE hex nuts will fit INSIDE the dace adaptors? Thanks guys!
Yes they will, the daces with fit the ue 14mm hexes:)
Thanks guys!! Really appreciate it!
The dace will take pretty much any 14 mm hex inside to make it 23mm. I thinking of going to them for my savage cause my pin has turned 90 degrees inside the proline hexes.
Well, then, you have plenty of torque! It seems they are worth it. I use the pro line 23mm now, my new UE axles are hexed on the end which totally emilinates the pins...so have to get the dace, which is fine cuz i should have "done it in the first place"
I run the dace on my ue. They are great. I don't have the problem i did with the prolines. I think you will like them better. If you have the proline wrench it works with the dace to. That is what i use.
No proline wrench, never could find one. Got a link? thanks! i bought the dace last night from Mike.
Actually, I don't know why the Proline wrench would work...It's 23mm when the nut on the Daces is 22mm...
Funny, I JUST read that on the store! lol, then i got your email to reply of post ....weird! 22mm socket should work fine then! I have that! yee haww! soon i can put my wheels on and go for a ride!
Still would like a link as i still have prolines too...please? And i agree, don't need a two foot ratchett! LOL, that was good!
| All times are GMT -4. The time now is 08:32 PM. |
