Feigao Speeds?
Just intrested for those who have a B/L system to say what speeds you get with:
Motor ESC Batteries Gear Ratio ...at a stable temperature? Thanks, Nick. |
I've made a 40 mph run (checked on gps) on 14 gp3300 cells,a feigao 9L and a schulze 18.97 . gearing 16/70 bowties. temps are fine on the motor with a fan in the summer.
phil |
Phil, did you test that motor in the rustler?
no it is in my E-maxx. I had the 8s and 9918 in the rusty. why?
phil |
Just curius.
ive hit about 35 with 16/66 gearing with an 8L on 12 cells and 9918. the controller was barely even warm.
mid 40's to upper 40's with an 8xl and 9918 with 24/64 gearing controller was cool but im have a fan on it ,with 16 cell have run 18 but u cant control it so i dont have an est on 18
Team Losi XXX-T MF1
32mph Feigao 8s MGM 80 amp 12 cells 3000mah 18/86 |
Here is a friends setup;
HPI savage (heavy weight champ) 15cells GP3300 Feigao 10L Schulze 18.68 topspeed 44mph |
now,
TL Matt Francis 1 42mph Feigao 8s MGM 80amp LiPo pack 3s 11.1v 18/86 |
whats up with some of these speeds...they seem a bit slow. i mean 12 cells in a mf1 and you are only getting 32mph???
I havent run my mgm yet, but with the novak 5800, 23/87 gearing, and 7 cells, i am hitting 52mph under test conditions ( on a stand) using the eagletree data system to measure. I realize i will loose some when running on the ground, but even with those losses, i will still be mid-40's. So i ask again, why are some of the speeds kinda low? |
i don't think that you have 52mph with the novak, I saw a novak setup last summer and it like a 19t chameleon and maybe a 15-16turns motor. the speed on the ground its not the same, find a gps and put it on.
for the speed with my 12cells its because the cells are not matched, for competition, there are cheap one. i paid something like 60$US for 4 packs. with GP3300 you will get over 40mph. |
What run times do you get with these Feiago set ups? Intrested mostly in 9L/10L motors...
personally i think gps in inaccurate cuz you have to carry the weight of the system. second, i never said that it wasnt overgeared and i did say it was on a stand. once you figure in losses, it is still at mid 40's. my eagletree is setup based on the gear ratios and tire diameters, its not based on measured rollout, so i feel pretty confident that it is accurate.
i have a novak and i would be surprised if you could get 40 out of it with 7 cells.
| All times are GMT -4. The time now is 08:19 PM. |
