-   -   Low Voltage Cut Off (https://www.rc-monster.com/forum/showthread.php?t=3461)
psycho 06.30.2006 02:25 PM
Low Voltage Cut Off
Hi Everyone!!!
If I conect in series two 3 cells Lipo packs for my G2R for an effective 6 cells pack, wich Low Voltage Cutoff should I use?
Do I need one 3 cells cutoff for each pack or one designed for a 6 cells pack?
Thanks:037:
squeeforever 06.30.2006 03:03 PM
1 designed for 6S should do the trick.
psycho 06.30.2006 03:16 PM
Thanks!
Where can I get one of those?:037:
squeeforever 06.30.2006 04:49 PM
Alot of people run the Li-Saver but it seems to be out of stock everywere. I think Mike has them. Try and e-mail him. By the way, what esc are you running?? The MGM and Quarks have a LVC built in.
neweuser 07.01.2006 10:33 AM
So if you get a quark controller, like the 125B, you would not need the lvc at all? that would be cool!
squeeforever 07.01.2006 11:01 AM
Yup, it's got one built in.
neweuser 07.01.2006 11:02 AM
Sweet. that would be the way i'd go. no wiring! no soldering! yeeehaaaw! that's what i would do psycho if money allows.
coolhandcountry 07.01.2006 12:04 PM
The mgm has to be programmed for different cell counts. The quark has a self detecting cell count. You just set what you want for the volt per cell cut off.
psycho 07.01.2006 03:27 PM
Thanks!
I allready have the BK 120.
:037:
coolhandcountry 07.01.2006 03:36 PM
The li saver seems to work decent. I don't know how many others are out.
