Need help on different saver
I need to use a different servo saver on my flamemaxx chassis than the normal one(the 2 arm's are in-line with eachother) I need the saver part to be like a crt saver, so the 2 arm's have an angle of 90 degrees.
If any of you know a saver that fit's the maxx ( 4 cm's high and both arm's from center to center 2 cm's) please share. Thank's in advance. |
Can you design a part that takes place of the top part where the servo hooks up?
That would fix you right up. |
Like I said before, your are a genious.
Have to look into it a little more, but it should work. |
| All times are GMT -4. The time now is 05:51 PM. |
