-   -   Turnbuckle ends (https://www.rc-monster.com/forum/showthread.php?t=3536)
phidailo 07.11.2006 08:51 PM
Turnbuckle ends
You know where I can get aluminum ends for the turnbuckle? The threads on the plastic ones in the front stripped.
squeeforever 07.11.2006 10:20 PM
I would stick with plastic. Somethings gotta give and not to mention, they will mess up your toe in adjustments.
phidailo 07.11.2006 11:01 PM
thanks
will the RPM rod ends work?
http://www2.towerhobbies.com/cgi-bin...?&I=LXALN0&P=7
If these do work, how are they secured since the hole is not hollow?
squeeforever 07.11.2006 11:32 PM
Those won't. There for TC's, 1/10th's, ect. There designed for a ball stud and not a hollow ball. I don't particulary like them because they pop off easily.
emaxxdriver18 07.12.2006 11:36 AM
these should work good http://www2.towerhobbies.com/cgi-bin...?&I=LXEMD2&P=7
