UE SuperShocks on stock suspension
Will the SuperShocks work with the stock suspension? I know they are longer, so was curious.
I ordered some last night from mike. |
Not without a minor modification. You need to put a small piece of fuel line or other spacer to limit the travel. Stock suspension can't handle such big shock's, had them myself on rpm arm's and without the spacer it sucked.
On the stock lower arms the bottom shock mount screw holes are raised up. If you were to cut these off and have the shocks mount onto the arm like a truggy. There is just a hole cut out in the arm for them to fit in and a hole for the screw. It would mean that the shocks would have to be about 15mm longer or so, to fit perfectly. I'm not sure how long the UE ones are. |
The ue I think are about 10 to 15mm longer than stock.
This is what I was meaning, if you can see it properly, it was only a rough attempt, final version will be done better.
http://i6.photobucket.com/albums/y21...hotobucket.jpg |
I would try to go farther out towards the pillow ball.
Make it closer to the outer hole that you cut off. |
can't you just flip the arms around?
Sure will, that's just a silly little prototype to see if you all caught my drift.
Serum - Id still have to dremel material none the less. |
Yeah, sounds fair to me, i guess it's the angle of the shock that gets in the way of the arm.
Yay, I made it work!
http://i6.photobucket.com/albums/y21...hotobucket.jpg http://i6.photobucket.com/albums/y21...hotobucket.jpg http://i6.photobucket.com/albums/y21...hotobucket.jpg http://i6.photobucket.com/albums/y21...hotobucket.jpg http://i6.photobucket.com/albums/y21...hotobucket.jpg http://i6.photobucket.com/albums/y21...hotobucket.jpg Gonna post a little 'How To' on the UE Forum later. Comments/flames/criticism etc... encouraged :) . |
Look's like you need to get some more practice with the 'ol dremel lol.
j/k nice mod. Hope your arm's won't fold if you land a jump hard lol. |
Wouldn't it have been easier to get some front buggy shocks.
Sneeck, I probably could, but it works.
CHC - I dunno, but I like the fact that they're UE. First UE part i've bought :) . |
Pick up a used set of UE Widemaxx arms for $100. It will look and work much better!
My .02 |
| All times are GMT -4. The time now is 10:20 AM. |
