Can I change the stock Spur and Pinion?
Is it possible to get higher top speed than stock if I change the stock spur and the stock pinion, leaving everything else (motor wise) the same?
Like if I go with the 54 tooth spur and a larger pinion? Whats the relative limit before things start heating up real bad? Edit: I am talking about the emaxx btw. Forgot to mention b4. |
you can just watch the heat cant really say what pinion/spur when you havent told us the car
I tried going up on my emaxx. I got the motors hotter with really no speed increase. Try more cells unless you running 14 now.
I am already runnin 14's. I just wanna take these motors to the max since I am pretty much ready for brushless. Just wwanna burn these before replacin em with a brushless one.
Well just do it and report back. :D
Then you can put a brushless on order while doing it. |
Thanx for the suggestion btw. |
If you are talking about the titans and evx, i run a 64 tooth spur with stock pinions and got about 4mph out of it, running 12 cells
| All times are GMT -4. The time now is 12:28 PM. |
