-   -   A little more brushless advice (https://www.rc-monster.com/forum/showthread.php?t=3635)
Puttinstankonia 07.23.2006 11:17 PM
Im not worried about the way my car handles i just want to go fast. I am currently running a 10 cell saddle pack setup with a 6t orion motor along with the novak xr on a 10th scale tourer and i would like to know what brushless system i should go with and what LiPo i should also go with in order to achieve great speed........
SpEEdyBL 07.24.2006 01:39 PM
A feigao/wanderer 540 12s on 4s lipo should get you to 70 mph at the least. Look for a 4s pack in the 50-70 amp range and you'll be good. There is no need to buy a pack that weighs more than say 14 ounces. That would just add weight and wouldn't improve top speed. I saw your other post. It's best to get two 2s packs and wire them in a series if you want saddle configuration.
Mike.L 07.24.2006 01:45 PM
what speeds are you getting out of your 6t motor??
Puttinstankonia 07.24.2006 02:36 PM
Im gettin speeds of probably about 50 out of the 6t maybe a little faster only got to run it full speed like once before the soder burned off the motor so i really dont know
Puttinstankonia 07.24.2006 02:37 PM
What speed controler should i go with to run that motor...
squeeforever 07.24.2006 04:06 PM
I would go with a Quard 80.
