7xl on 14 cells too little? (torque wise)
is a 7xl on 14 cells too little (in terms of torque) for an e maxx? and what controller would i need for a 7xl if it isnt too little?
Thanks! SB |
I ran mine on 14, was good fun, really enjoyed it, just when I went to 16, then 18, I never wanted to go back. :005:
I'm thinking of getting a 6XL and running 14cells. So the packs are more universal across the other cars I use. A 7720 would run the XL and 14cells fine, I use the 9920 myself. |
It is a good motor on 14 cells. I would get a 9920 unless you going to keep gearing down.
thanks nick and coolhand.
nick- do you mean 7020? as i cant find a 7720 on rc-monster and ive got a 7020 already so i'd have a cheap setup (which would be nice, im cheap lol) h yeah what gearing would you reccomend for the maxx? as ive found a nice one, which im going to run 14 cells on the stock motors till they go pop, and upgrade along the way. SB |
If you going to run the 70 20 I would go or try a 15 66. On 14 cells it be torque but should be ok on heat on esc. Keep an eye on temps.
Thanks! SB |
20T would be quite warm...i would start 12/51 would be close to 15/66,and work your way up. I run a 9920/10xl on 16 cells geared 18/51 and stays good...but that's in a maxx.
I ran 20/66 without strobe... stock gearing. On 14 cells no heat problems at all! :)
Yes, I did mean the 7020. |
With what diffs?
I think your gonna run hot with that, what diffs are you running? But then again, i have never ran stock with BL LOL, let me know how it goes....I thought you had a strobe for some reason... :)
he's got back to me, and he says there stock. im thinking of running maxximiser diff cups. would that be strong enough?
SB |
| All times are GMT -4. The time now is 07:06 PM. |
